Activity › Forums › Adobe After Effects › Specified number of anchor points on shape… (for morphing in AE)
  • Specified number of anchor points on shape… (for morphing in AE)
    Posted by Christof Van niekerk on June 12, 2017 at 9:54 am
    Problem:
    I have a series of contour shapes (think of map contours – 80 of them!) , that I want to animate/morph between in AE.
    Problem is… these don’t exist as vectors & are traced in Illustrator which yields a range of different anchor point numbers & positions for each shape. So after tracing I bring the vector shapes into AE… i make sure to select a consistent corner for all shapes & go “layer>shapes&masks>set first vertex”…. which at least keeps the path direction & start consistent for the morph.
    Is there a way to specify more consistent placing ( & number of) anchor points when these shapes are traced… in order to get a more accurate morph/tween in AE?
    Thanks for any suggestions/advice up front,
    Christof
    Christof Van niekerk replied 9 years, 3 months ago 2 Members · 3 Replies
  • Roei Tzoref
    June 12, 2017 at 5:32 pm
    You can try smart mask interpolation but this only applies to mask paths ( you can copy the shape path to the mask path and copy back when you are done). Look for smart mask interpolation article by chris and trish meyer. You can also try morphing in illustrator using the blend tool, and import as a sequence – Rick Gerard has a tutorial about it in his YouTube channel RGEFFECTS
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
  • Christof Van niekerk
    June 13, 2017 at 8:50 am
    Hi Dave… thanks for the reply.
    Perhaps I wasn’t clear in my explanation…. the actual brief from client, is to have smooth transitions from contour to contour…. in saying “morph”, I meant animate between these shapes/masks. (these are geographic samples of taken over a number of years of a mountain/dam for example) … and the clients wants to see the they do not exist as vectors.
    So I’ve traced these contours in illustrator….paste them as masks in AE… and the animation is happening – but the anchor points are obviously all over the place. (even after setting first vertex on all of them)
    I imagine that with a specified number of points on each path/contour…. AE would animate between them all more predictably. (hence my attempts to resample these vectors somehow with a specified number of points, and a corresponding starting vertex)…. but any other approach/suggestions are welcome
    Thanks a mil for your help
    June 13, 2017 at 8:52 am
    Roei!! … these sound promising! – quickly going to look into it. Many thanks for the help.
