Activity Forums Adobe After Effects Specific motion tracking question
  • Specific motion tracking question
    Posted by Brad Hebert on April 25, 2012 at 11:18 pm
    Final Cut expert, yet After Effects noob, here.
    I have a slow pan of a room with a bunch of x’s taped on the walls to motion track. I’d like to link images to each point, basically 2D pictures, that will float in the air as the camera pans by.
    I’ve searched through online tutorials and understand how to set tracking points, but I’m not sure how to achieve the offset from the wall I’m looking for. Also, I want the perspective of the pictures to shift and remain parallel to the wall.
    Any help is very appreciated!
    Brad Hebert replied 14 years, 4 months ago 4 Members · 4 Replies
  • Andrew Somers
    April 26, 2012 at 1:07 am
    The After Effects tracker probably won’t do what you need – it sounds like you will need a true 3D track, and then import the 3D camera into After Effects.
    Though you *may* be able fake what you want – using expressions with the “toComp” function may help:
    https://help.adobe.com/en_US/AfterEffects/9.0/WS3878526689cb91655866c1103906c6dea-79fda.html
    https://provideocoalition.com/index.php/cmg_keyframes/story/dmoe4_space_conversions/
    https://provideocoalition.com/index.php/motiongraphicsvizfx/story/expression_shorts_-_attach_2d_layer_to_a_3d_layer/
    And also, a MOCHA track might get you close enough that you may be able to offset some planar tracks to get the look you are going for.
  • Chris Buttacoli
    April 26, 2012 at 8:27 pm
    EXCEPT…. a pan has no perspective shift. A dolly or track shot that moves through space is what causes perspective parallax. And to track a shot like that, you would need a 3dTracker, like the one from the Foundry for AE. For a pan track, the AE tracker should work just fine.
    Maybe you are using the “pan” lingo incorrectly??
  • Roland R. kahlenberg
    April 27, 2012 at 6:13 am
    Without looking at the shot, it’s impossible to offer definitive solutions. A 3D tracker should work but mocha should also work.
    To get what I call, ‘induced parallax’ (ie creating parallax in post), you can switch a 2D layer into a 3D layer and then offset/move it in z-space. The abbreviated process starts with a track with mochaAE/mochaPro, applying the tracked data to your layer in AE (2D layer), switching the layer into a 3D layer, offsetting the layer in 3D space to create an instance of ‘induced parallax’.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Brad Hebert
    April 28, 2012 at 4:08 pm
    Thanks! I was thinking there might be an “easy” (if a bit rough) way of doing it. Being pretty new to motion graphics, this is the only option for me right now. Good to know the more advanced options as well.
