Activity › Forums › Adobe After Effects › Specific matte question
  • Specific matte question
    Posted by Skylar Moran on November 14, 2016 at 10:42 pm
    Hello,
    I am trying to recreate a rather retro effect, but for some reason I am banging my head against a wall trying to find a simple solution to create it.
    I have this text with a heavy shadow effect on it. Here’s a screengrab.
    I want to have the white part of the text wipe on and reveal the orange shadow. I have each on separate layers. I tried using the echo effect on a matte of the text part to create a wipe-on effect, but that isn’t working as smoothly as I hoped, so here I am searching for another creative idea. Any takers?
    Chris Brett replied 9 years, 10 months ago 2 Members · 1 Reply
  • Chris Brett
    November 15, 2016 at 12:07 am
    Hi Skylar
    —- I dont think its clear what you are trying to do – if you mean…
    1 ) wipe on type with outline and fade up extruded flat drop shadow then :
    —- draw a mask over the type and set it to subtract – this will mean you can not see it
    —- go to start of animation and set keyframe on mask path
    —- go to end of animation and select ‘mask path’ to drag the left hand side of mask to the right revealing text ( if left to right ) – set feather to suit if wanting soft edge
    — go to other layer with drop shadow and animate transparency to suit
    2 ) If you mean ‘grow’ the drop shadow from the type with the outline then you will be able to do this using a custom matte ( you could just draw this with the pen tool or go to PS for a black and white ) — just slide it in from ‘behind’ the type by selecting the custom matte as the track matte — you might need a version of the drop shadow with the outline and type as well ( set to orange ) to make the join easy
    …. I guess you could do this with C4D but I think it will be hard to match the flat retro look ( ? ) — I dont use it myself so I could be wrong ( ? ) — however if you like the 3D look you can also do this in an older version (s ? ) of AE that have the 3D option ( where you can extrude vectors as in a dedicated 3D package )
    ———————————- good luck —- chris
