Special FX
Posted by Douglystyles on November 21, 2005 at 10:22 pmIm looking for a way to single out an area in a video and change its color. For example, in shindlers list, how it was all black & white, except for the red dress… Im looking to do something similar to that.
First question… Is that possible in Vegas?
Second question, if Vegas cant do it, is there a program that that is possible (final cut pro, after effects… or somthing in the Sony (sonic foundry) family)?
Russell Heimlich replied 20 years, 9 months ago 5 Members · 6 Replies -
Gary Kleiner
November 21, 2005 at 10:34 pmThis color pass techinique is done with the Secondary Color Corrector.
Use the ‘select effect range’ eydropper to drag across the color you want to keep (in preview window).
Click on invert mask, then pull down the saturation. This will leave your defined color intact and the rest will be desaturated.
Gary
Edward Troxel
November 22, 2005 at 3:37 am -
Harold Brown
November 23, 2005 at 2:52 amGary Kleiner has an excellent DVD that shows this effect and a lot more. I recommend it.
Harold
Russell Heimlich
December 7, 2005 at 7:10 amYup it sure is possible. Check out a video i did with this technique:
https://video.google.com/videoplay?docid=9168541128795918736&q=russell+Heimlich
Sorry for the long black in the beginning. I uploaded the wrong file.
I have a free filter called Aav6cc. It had a preset for filtering out everything but red and i just dropped it on and was good to go. Very lucky for me how it worked out with my project.
Here’s where you can get it -> https://www.moosehill.se/
Russell
https://www.RussellHeimlich.com -
Edward Troxel
December 7, 2005 at 2:44 pm -
Russell Heimlich
December 7, 2005 at 6:01 pmI just happened to download this one day and it had a red=pass preset, so i just dragged and dropped it on. I don’t know if there is any real advantage other than it is simple. Ofcourse, you could always make a preset for the secondary color corrector. Below are the advantages of his plugin quoted from his site:
# Directly adjust Reds, Greens, Blues, Cyans, Magentas and Yellows without having to “pick” the colors. All six color vectors can be adjusted independently using only one instance of the plugin. (Sony’s secondary corrector would require up to SIX instances!)
# Currently allows Hue, Saturation and Lightness (HSL) adjustment.
# Invert your selection to adjust everything but a certain channel.
# 32-bit floating-point precision used internally for high quality (accelerated by SSE/3DNow!).Russell
