Activity Forums Adobe After Effects Special Auto Lip Sync
  • Special Auto Lip Sync
    Posted by Ángel Molina lópez on February 2, 2019 at 3:18 pm
    Hi everybody:
    I want to make a Dorkly animation (https://www.youtube.com/watch?v=ZVTLsQ8iNCM), that is, 8-bit puppets opening and closing their mouths. The difference I want to add is when the mouth is open the puppet get stretched (scaled) in the Y axis and when is closed the puppet returns to its original size. I have managed to get a semi-automatic sync method but it still takes up too much time. Can you think of any automatic or quasi-automatic method? I’ve seen things get done with Adobe Character but I don’t know if it would work with the scale issue.
    Regards and I hope I made myself clear.
    Ángel Molina lópez replied 7 years, 7 months ago 2 Members · 3 Replies
  • Ángel Molina López Create COW Profile Image
    Ángel Molina lópez
    February 2, 2019 at 5:24 pm
    I want that effect while they are just talking. It’s not something specific. Some syllables will match with an open mouth and streched body and others with a closed mouth and normal body.
  • Kalleheikki Kannisto
    February 3, 2019 at 9:39 am
    You can use audio to keyframes result with a simple piece of expression code that sets the threshold of when to stretch the pixels.
    Senior Graphic Designer
    Ángel Molina lópez
    February 6, 2019 at 4:09 am
    Thank you for your replies. Kalleheikki, the technique you have spoken of is the one I’m using now, but I was looking for something more automated. I’ve been searching and I think I’ve found a way. Lars is a genius (https://vimeo.com/220359572) and has made an expression that allows the transfer of keyframes from CA (Character Animator) to AF and it works perfectly well. It saves you a lot of time.
    Now, the scale problem. I’ve assigned a null that responds to the values adopted by the mouth so I tasked it when the mouth is open, the puppet stretches. To do this, I’ve used the following expression:
    x=thisComp.layer(“SIDE MOUTH GREEN”).effect(“LJ – visemes – MSD”)(“viseme nr.”)
    if(x==1)[148,199];
    else if (x==3) [148,199];
    else if (x==7) [148,199];
    else if (x==10) [148,199];
    else if (x==11) [148,199];
    else [148,189];
    The problem is as follows. When there are two consecutive sounds that are equivalent to an open mouth (FOR – GO – tten), the puppet doesn’t move and that’s a pretty dull stuff. What should be said to AF is: if after an open mouth value goes another open mouth value, on the changed value disable the stretching for X time. What’d be the expression that would be needed to achieve that? I know I could do it manually but I want to broaden my skills.
    Thank you in advance.
    PS: Is there any way to shorten the expression I have written?
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
