Activity Forums Adobe After Effects Spec Delivery Query
  • Spec Delivery Query
    Posted by Pat Bray on May 19, 2011 at 5:07 pm
    Hi
    I’ve been asked to deliver to this spec but its an aspect I’ve not worked in before, any advice would be great:
    HD DATA as DPX, Tiff or Targa Sequence, prepared with the correct ratios for cinema projection (I believe they are shooting, 2.40:1)
    I usually work at HD 1920×1080 (sq pixels) for broadcast not cinema….
    P
    Pat Bray replied 15 years, 3 months ago 2 Members · 2 Replies
  • Walter Soyka
    May 19, 2011 at 5:48 pm
    [Pat Bray] “HD DATA as DPX, Tiff or Targa Sequence, prepared with the correct ratios for cinema projection (I believe they are shooting, 2.40:1)”
    As I’m sure you’ve noticed — this is not a very specific spec!
    I’d ask what exact pixel dimensions they expect you to deliver. I’m not clear if HD is supposed to stand for high-definition or hard drive.
    If you deliver DPX, you should find out whether they expect log or lin DPX files. If you deliver TIFF, you should find out whether they expect 8 or 16 bit TIFF. Targa is 8-bit only, so that one is pretty straightforward once you know the resolution — but if the system can handle the additional depth, you could work in 16bpc in AE and deliver DPX or 16-bit TIFF.
    Walter Soyka
  • Pat Bray
    May 20, 2011 at 2:41 pm
    Thanks for your comment, I know, the reply I had was a bit flakey! Still trying to find out what they want, hopefully someone will tell me soon!
    Cheers
    Pat
