Activity › Forums › Apple Final Cut Pro Legacy › Speakers out of sync with FCP
  • Speakers out of sync with FCP
    Posted by Sandust on May 31, 2005 at 5:19 am
    Aloha,
    I am using a MOTU 896HD to listen to the audio with FCP 4.5. My audio is 3 frames out of sync when going to the MOTU. How can I correct this? If I play back to my G5’s built-in audio everything is in sync.
    Mahalo,
    Dusty
    Dual 2.5Ghz G5 w/ 2.5GB ram, Decklink HD, Decklink Multibridge, MOTU 896HD
    JVC DV5000, 2 Sony HDR-FX1, JVC BR-DV3000U, JVC 19″ HD monitor
    Walter Biscardi replied 21 years, 4 months ago 2 Members · 1 Reply
  • Walter Biscardi
    May 31, 2005 at 11:13 am
    Sounds like your audio output is set to “Built In Audio” rather than whatever device you’re using to feed your video monitor. Audio and Video must come from the same source to be in sync.
    You can also use your “Playback Offset” to change this. Default is four frames. I always need to reset this to Zero whenever I trash prefs to ensure that the audio from the Kona 2 is in sync.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
