Activity Forums Audio speaker vs guitar speaker
  • speaker vs guitar speaker
    Posted by Tom Delacarey on February 23, 2009 at 12:41 am
    What exactly are the differences (in sound) between a regular speaker and a guitar speaker? I know that a guitar speaker is thicker, a bit more heavy duty. I want to try to use a normal speaker with a guitar cabinet speaker, the only negatives that I can think of in doing this is that distortion might not work as well (otherwise this speaker has the correct hz ranges, watts, etc). Does anyone know of other possible problems?
    thanks
    Steven Talley replied 17 years, 7 months ago 3 Members · 2 Replies
  • Jordan Wolf
    February 23, 2009 at 1:37 am
    Usually, guitar speakers are full range, in that they are made and expected to reproduce the entire frequency range of whatever is coming to it from the amplifier. A loudspeaker, on the other hand, usually is only meant to handle a certain bandwidth. A 3-way cabinet would have three different drivers (loudspeakers); the [sub]woofer (debatable terminology) would handle 50Hz-120Hz, the woofer would handle 110Hz-4.5kHz, and the high frequency driver would handle 4kHz-18kHz. That’s all theoretical and not necessarily based in fact, mind you, but I think it gives you an idea of the differences.
    Anyone else care to add?
    Wolf
  • Steven Talley
    February 24, 2009 at 5:51 am
    Sounds good to me, I’m using (at home)a 15″ Subwoofer driver in a home made speaker cabinet running from a small Fender amp head and it sounds pretty good. Wouldn’t use it on the road though.
