Activity › Forums › Apple Final Cut Pro Legacy › speaker off while log and capture
Posted by Moztu on July 26, 2005 at 10:58 amHi!
We are capturing some media but would like to listen while logging. We have actualized our FCP form 4.0.1 to 5.0.1 and can
Jake Burns replied 21 years, 1 month ago 3 Members · 2 Replies -
Arnie Schlissel
July 27, 2005 at 6:38 pmBoth your speakers & your video monitor should be connected to your deck while capturing & laying off to tape. That way, you’re always monitoring what’s on the tape.
Arnie
https://www.arniepix.com -
Jake Burns
August 16, 2005 at 12:57 pmI disagree
You should always monitor the computer output during capture (as with any recording device) so that you can see/hear what you are actually capturing. This is much more important than seeing/hearing what is on the tape (but which may not be going on to the FCP system). Then yes, when playing out you should monitor the deck to see what is being laid to tape.
Doing it any other way leaves room for error when capturing. BUT there have been reports of ‘popping’ during capture as the system upconverts the audio for playback.
On the original question – yes this option is missing from it’s old place and I badly need to have it back again. We will have to re-route a lot of cabling from our decks unless I can find a way round.
Any suggestions anyone on how to switch the speaker to ON as inFCP 4?
jake Burns
Jake Burns
Western Eye Television
Final cut studio
Cinewave 4.7
G5 2Gb RAM
PAL
Parley Cross, UK
