Activity Forums Apple Final Cut Pro Legacy Speaker Off During Logging and Capturing in 5.14?
  • Speaker Off During Logging and Capturing in 5.14?
    Posted by Chris Parkhurst on June 11, 2007 at 11:00 pm
    For some reason I am finding it difficult enabling my speakers to play during logging and capturing. When I go to my Capture Presets (within Audio/Video Settings) and look in the Summary I see that I have my Speaker turned off. In the past, I would simply open up my Capture Preset settings and within this tab I would locate the Quicktime Audio Settings. Here there would be an Advanced button which I would click. From here I could simply select Speaker Off While Recording from the dropdown menu. This was in prior versions to Final Cut (HD) that I was using. I’m now using Final Cut Pro 5.1.4, and there doesn’t seem to be that Advanced button any longer..?
    Is there another place that I now need to be looking? Has this been moved? How can I change whether or not I want my speakers on while logging and capturing?
    In advance, thank you for your valued input!
    Chris Parkhurst replied 19 years, 2 months ago 3 Members · 3 Replies
  • Mfassett
    June 11, 2007 at 11:41 pm
    Yes, it has been moved… and I find it strange too. When you bring up the “log and capture” window, you can find the option in there (can’t remember exactly where, but there’s a checkbox you need to select).
    https://www.mfassett.com
  • Neil Ryan
    June 12, 2007 at 3:08 am
    Log & Capture, ‘Clip Settings’ tab.
    under the Audio section; check ‘PREVIEW’ on.
    Is that what you’re looking for?
    Neil Ryan
    Post Production
    The Pod Multimedia
    http://www.the-pod.com.au
  • Chris Parkhurst
    June 12, 2007 at 3:55 am
    I think that you may be right. Strange that they moved it in the first place. Thanks for the help, guys!
