Activity Forums Apple Final Cut Pro Legacy Speaker hum when I connect my external computer monitor
  • Speaker hum when I connect my external computer monitor
    Posted by Sean Mcphillips on August 3, 2008 at 12:40 am
    I’ve just bought a pair of KRK Rokit 5 powered speakers to plug into my MacBook Pro (via the unbalanced audio/headphones out plug) for monitoring audio out of Final Cut Pro (for example).
    They sound great until I plug my external computer monitor (Samsung Synchmaster 205BW) into the MBP – at which point I get a loud hum through both speakers.
    According to the Rokit 5 manual any video monitors have to be on a different circuit than the speakers, so I went and got myself a couple of extension leads and proceeded to plug the Synchmaster into every power point I could find in our office (seven in total), and got the hum every time.
    Now there are four power circuits in this office so unless all the points are coming off only one of them for some reason, that doesn’t seem to be the problem.
    Has anyone else had this issue?
    Any help appreciated,
    Sean
    Sean McPhillips
    Sean Mcphillips replied 18 years ago 7 Members · 9 Replies
  • 9 Replies
  • Sean Oneil
    August 3, 2008 at 4:17 am
    Computer speakers are horrible. They pick up any type of noise there is. Having a cellphone even near them is going to cause a really loud hum. You should return them.
    Sean
  • Steven Gonzales
    August 3, 2008 at 2:21 pm
    You might have a ground loop problem. You might want to try a high quality isolation transformer on the audio:
    https://www.jensen-transformers.com/ci2rr.html
    Here’s an article on the subject of ground loops in audio:
    https://www.rane.com/note110.html
  • Chuck Reti
    August 3, 2008 at 4:44 pm
  • Chuck Reti
    August 3, 2008 at 5:05 pm
    [Sean ONeil] “Having a cellphone even near them is going to cause a really loud hum.”
    (Sorry for inadvertent blank post above.)
    The digital signal that the current generation of GSM/G3 phones generate gets into almost everything, not just nearby speakers.
    On both studio and EFP shoots, we have to make sure crew and talent cell phones are in the full Power OFF, not just ‘silent/ring off’ mode to avoid the buzz getting into both wired and wireless mikes. Same with studio headsets and intercoms. Have heard this even on radio programs when talent’s phone gets into the audio board. This will occur all by itself, when the cell phone and nearby tower sites need to communicate with each other, not just when a call is in progress.
    As to the OP’s hum problem, it does sound like a ground issue, which can affect audio monitoring regardless of the equipment price or manufacturer. Besides the recommendation to try an isolation transformer (though i suspect everything’s on wall warts anyway), sometimes careful re-dressing of power and audio cables can help. Make sure speakers and speaker leads are nowhere near power supply or mains cables and especially transformers.
  • Colin Mcquillan
    August 3, 2008 at 9:44 pm
    You could give this a go!
    https://www.maclife.com/article/iphone_buzz_kill
    Other than that,, well,, you are plugging into the KRK’s unbalanced,, Make sure the wire going from your computer to the speaker isn’t running along side any AC cables, power adapters, so on… If you have to pass over an AC cable, do so at a 180Deg angle.
    Also, try to use a decent cable. If you’re using a thin radioshack’ish mini-plug to RCA cable with thin to no shielding, you will pick up all sorts of ugly frequencies.
    Colin McQuillan
    Van. B.C.
  • Sean Mcphillips
    August 4, 2008 at 4:17 am
    Ok, so I have a bit of work ahead of me to figure this out.
    I’ll post here again once I’ve had a go at it.
    Cheers,
    Sean
    Sean McPhillips
  • David Bogie
    August 4, 2008 at 3:00 pm
    q[Sean McPhillips] “I’ll post here again once I’ve had a go at it. “
    And please go back to all of the other forums where you have posted this same question.
    You’ve gotten a weird range of mutually exclusive advice and suggestions on how to handle interference caused by many different sources. We would like to know what worked and what diddn’t.
    bogiesan
  • Fixer Aka robert smith
    August 5, 2008 at 1:28 am
    I concur with the ground loop suspicion and isolation transformer recommendation.
  • Sean Mcphillips
    August 5, 2008 at 2:13 am
    Ok, so I’ve found a ground loop isolator that sounds like it’ll solve my problem here…
    https://www.minidisc.com.au/xitel-ground-loop-isolator-p-423.html
    My next question is, if that fixes the problem, do I still have to worry that there is a ground loop problem in the building? Is it inherently dangerous or just a fact of life?
    I understand that a power conditioning unit would be another possible fix and probably a good idea generally but to solve this problem, at AU$60 v AU$500+ I’d rather go with the cheap option at this stage.
    Does that sound reasonable?
    Thanks to everyone for their input.
    Sean McPhillips
