Activity Forums Blackmagic Design SPDIF to AES
  • SPDIF to AES
    Posted by Pol on August 1, 2005 at 10:16 am
    I’v done some reading and it seems that the SPDIF outputs on the BMcards are essentially AES outputs. The signal just needs a minor adjustment.
    I wonder how you can convert the SPDIF signal, everytime I go to a pro audio shop they want me to buy a whole box to convert the signal (cost 200
    Sven Hanten replied 21 years, 1 month ago 5 Members · 6 Replies
  • Ray K
    August 1, 2005 at 12:19 pm
    do a google search for HOSA CDL 313
    they work great
    regrds
    ray
  • Pol
    August 1, 2005 at 12:37 pm
    Good start, but it’s only 16bit (probably not an issue)
    Other options?
  • Richard
    August 1, 2005 at 2:49 pm
  • Pol
    August 1, 2005 at 3:52 pm
    Not bad….Is there anyone out there that actually uses this device?
    No doubt that it will work but they definitely forgot to hire a product designer.
  • Rupert Watson
    August 2, 2005 at 11:12 pm
    Murraypro stuff works; he is an engineer,not a product designer. When he says elegant he does not meean brushed steel and Aqua, he means it does the job properly all the time. Although I notice he refrains from calling it the world’s highest quality converter.
  • Sven Hanten
    August 3, 2005 at 10:44 am
    Another solution is:
    https://www.behringer.com/SRC2496/index.cfm?lang=ENG
    It is a multistandard converter with analog, AES/EBU, SPDIF, In- and Outputs in 24kHz/96Bit, for just US 150,-.
    My two cents,
    Sven
