Activity Forums Blackmagic Design S/PDIF out constantly losing valid signal
  • S/PDIF out constantly losing valid signal
    Posted by Jeremy Evans on August 3, 2006 at 3:59 pm
    Hi All,
    I’m monitoring my audio out of my Decklink Pro 4:4:4 card using the Flying Cow and S/PDIF OUT cables attached to the external pigtail. Every time I switch between apps, I lose the valid digital signal and it freaks out the Cow. Sometimes it even loses a valid signal while editing. I then have to reset the Flying Cow or even wiggle the pigtail in the back to bring it back. Is anybody successfully using this setup or is there something wrong with my card?
    Jeremy Evans
    Kristian Lam replied 19 years, 9 months ago 2 Members · 3 Replies
  • Kristian Lam
    August 4, 2006 at 8:07 am
    Hi Jeremy,
    The next time you lose SPDIF output, try jiggling the breakout cable on the back of the card and see if it makes a difference.
    It could be a bad converter or a bad DeckLink card. We’ll be happy to swap it out for you if we can verify this.
    regards
    Kristian Lam
    Blackmagic Design
  • Jeremy Evans
    August 4, 2006 at 1:38 pm
    Hi Kristian, thanks for the reply.
    This is exactly what is happening. Who do I contact?
  • Kristian Lam
    August 5, 2006 at 5:57 am
    Hi Jeremy,
    Jiggling the breakout makes a difference? And is it screwed in tightly?
    Send me an email at support[at]blackmagic-design.com. Remember to include the serial number of the card (found on the card and box below the barcode sticker).
    regards
    Kristian Lam
    Blackmagic Design
