Activity Forums Blackmagic Design Spdif audio missing
  • Spdif audio missing
    Posted by Peter Wiggins on April 13, 2007 at 12:10 am
    I’ve installed the 6.1 driver on my G5 PPC that has a Decklink Pro.
    I’m running 10.4.9, latest quicktime, FCP etc
    The audio from the spdif output has disappeared, nothing and nothing down the other 3 either.
    This is the same if I route the system audio out of the Decklink too. Sound is being embedded in the SDI output.
    Peter
    Luke Maslen replied 19 years, 4 months ago 2 Members · 1 Reply
  • Luke Maslen
    April 17, 2007 at 4:23 am
    Hi Peter,
    As a quick sanity check, would you please test uninstalling the v6.1 drivers and revert to the last ones you were successfully using? If that fixes the problem, then we’ll need to take a look at what’s changed. If that doesn’t fix the problem, then the driver update was a coincidence and the problem lies elsewhere.
    Regards,
    Luke Maslen
    Blackmagic Design
