Activity Forums Apple Final Cut Pro Spatial Conform set to “None” is making my video clips blurry?
  • Spatial Conform set to “None” is making my video clips blurry?
    Posted by Heath Alseike on April 22, 2015 at 10:52 pm
    I shot a couple of interviews at a 1080 resolution. My client wants the final video in 720. When I drop the original 1080 clips into a 720 timeline with the spatial conform set to “none” so I can frame the interviewee a little closer and better the footage looks really blurry. The clip is not scaled up at all, no filters or adjustments yet. I can not figure out why this is happening. Can any one help or explain the issue. Please and Thank you.
    Side not I did read a few other forms on similar problems however, they did not help. I rendered the video out and it was still blurry. I also tried the same thing in After Effects and it did not get blurry. I realize I can export if form After Effects and I am good, but that is way to time consuming.
    Bret Williams replied 11 years, 5 months ago 6 Members · 7 Replies
  • 7 Replies
  • Noah Kadner
    April 22, 2015 at 11:23 pm
    Can you post a screenshot of your timeline and project settings?
    Noah
    FCPWORKS – FCPX Workflow
    Call Box Training
  • Craig Seeman
    April 23, 2015 at 2:01 am
    I think there’s a best performance, best quality setting which might have impact. Just a wild guess because it does bite a few people when they think there’s a quality issue that shouldn’t be there.
  • Bret Williams
    April 23, 2015 at 4:59 am
    If it is a bug you could always try setting it to fit and scale it up 150%.
  • Scott Witthaus
    April 23, 2015 at 1:17 pm
    As noted, the dropdown menu on the upper right of the viewer has options for Better Performance or Better Quality. Choose quality.
    Scott Witthaus
    Senior Editor/Post Production Supervisor
    1708 Inc./Editorial
    Professor, VCU Brandcenter
  • Jeff Kirkland
    April 23, 2015 at 1:32 pm
    If it was the performance setting it shouldn’t affect rendering but the OP says it rendered blurry. Maybe try a new project or library and see if it’s just something weird with that particular timeline?
    Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
    http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland
  • Heath Alseike
    April 23, 2015 at 2:20 pm
    Awesome, thank you everybody for helping me out. The quality was set to better. I ended up creating a new project and that did work. I don’t know what was wrong with the first one but, good call and thank you Jeff. So simple.
  • Bret Williams
    April 23, 2015 at 11:34 pm
    That setting only applies to playback. Rendered or otherwise. While paused you’ll see full quality.
