Activity Forums Apple Final Cut Pro Legacy Spanish subtitles: fonts
  • Spanish subtitles: fonts
    Posted by Dave Felder on August 12, 2005 at 9:06 pm
    Any suggestions on how to put Spanish subtitles into my program? The text was typed in a Word for Windows document. I saved it as a TXT document. I was planning to cut and paste from the TXT file into FCP’s lower third text effect. But when I open the TXT on the G5, the accent marks are being replaced by capital letters. I realize this has something to do with differing ASCII codes, or something like that.
    Is there a particular font I can use that will have the proper accent marks?
    Thanks in advance . . . .
    Ryan Video Productions Inc. Rockaway, NJ
    Dave Felder replied 21 years, 1 month ago 3 Members · 3 Replies
  • Jerry Hofmann
    August 13, 2005 at 1:39 am
    Might try using the same font that the word doc used?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Susan Wilcox
    August 14, 2005 at 10:55 pm
    I do Spanish all the time. You’ll have to delete and then retype the letters that need accents. You can use any font you want, but you need to memorize the codes. They aren’t that hard once you get going. Use the Option key and the letter that designates the code first, then type the letter over which you want the accent. For example,
  • Dave Felder
    August 15, 2005 at 1:25 am
    I opened the actual Word document instead of a text only version of it. Textedit picked up all the proper formating with the Spanish accents. IOW, Textedit seems to read Word DOC format pretty darn well.
