Activity Forums Adobe After Effects Expressions Spacing between layers
  • Spacing between layers
    Posted by Brian Holzknecht on November 6, 2019 at 2:01 am
    So I have a pretty basic setup, I just have a bunch of layers lined up and have a slider control to control spacing, but what I also want, is an additional slider control to control spacing of every 3rd layer, and I’m not sure how to go about that. Here is the current expression I have on all the layers position.
    Brian
    xPos = thisComp.layer("expression").effect("location")("Point")[0];
    yPos = thisComp.layer("expression").effect("location")("Point")[1];
    spacing = thisComp.layer("expression").effect("spacing")("Slider");
    [(xPos)+((index-1)*spacing), yPos]
    Jakob Wagner replied 6 years, 10 months ago 2 Members · 3 Replies
  • Jakob Wagner
    November 6, 2019 at 11:39 am
    Hi Brian
    Try this:
    layerIndex = (index-1);
    groupSpacing = thisComp.layer("expression").effect("group spacing")("Slider");
    groupSize = thisComp.layer("expression").effect("group size")("Slider");
    layerSpacing = Math.floor(layerIndex/groupSize)*groupSpacing + layerIndex*spacing;
    [xPos+layerSpacing, yPos];
    I have added a couple more sliders. If you want you can simply set groupSize to 3, but I thought it was fun to have it as a slider.
    All the best
    Jakob Wagner
  • Brian Holzknecht
    November 6, 2019 at 5:13 pm
    Thanks Jakob,
    That worked perfectly and much simpler than I thought it would be. Much appreciated.
    Brian
  • Jakob Wagner
    November 6, 2019 at 5:35 pm
    You’re welcome. 🙂
