Activity › Forums › DaVinci Resolve › Spacial NR causing blocking pixelation
  • Spacial NR causing blocking pixelation
    Posted by Nat Jencks on October 30, 2014 at 2:17 am
    I’m on the most recent build of v11 and seeing an issue where spacial NR is causing pixelation / blocking. As if it was being reduced to a lower resolution. Workaround is to use NeatNR for now, but its annoying.
    I have not seen this before. Anyone else seeing this? This particular system is a nMP 12core 2xD700 64GB RAM
    best-
    -Nat Jencks
    Robert Ober replied 11 years, 11 months ago 3 Members · 2 Replies
  • Andi Winter
    October 31, 2014 at 10:50 pm
    can you post a picture?
  • Robert Ober
    October 31, 2014 at 11:09 pm
    [Nat Jencks] “I’m on the most recent build of v11 and seeing an issue where spacial NR is causing pixelation / blocking. “
    Only on playback or did you actually output a file and it has the issue?
    Curious,
    Robert A. Ober
