Activity Forums Adobe After Effects “Space” Character is different than in other applications
  • “Space” Character is different than in other applications
    Posted by Lennert Daniëls on December 14, 2015 at 12:46 am
    Hi folks,
    So I’m working on a project in After Effects CS6 (Windows), and I’m using the Impact Label font.
    As you can see, all characters are supposed to be surrounded by a box in the chosen color. The letters themselves are transparent. The “space” character should just be a box, without any transparent parts, but in After Effects, all spaces just show completely transparent.
    I’ve checked the font in Microsoft Word, Photoshop (CS6), and even in FontCreator: the space character should definately be an opaque box.
    Is After Effects replacing it by it’s own version of the space character? Is there a workaround?
    You can download the font here for testing. Let me now if it’s the same in AE CC.
    Thanks in advance!
    Lennert
    Lennert Daniëls replied 10 years, 9 months ago 3 Members · 5 Replies
  • Lennert Daniëls
    December 14, 2015 at 9:27 am
    That would be a cumbersome workaround for 100+ text layers…
    If you take a look at the font download page, you can see this “box” is actually part of the font.
    EDIT: I’ve tested another font with a non-blank space character: “Top Secret“.
    AE just uses a blank space instead of the font-specific space character. Works fine in other applications though…
  • Cassius Marques
    December 15, 2015 at 10:56 am
    have you tried imputing the character map’s number of space? alt+0160 ? It is still cumbersome but at least copying and pasting is faster than manually positioning rectangles.
    Cassius Marques
    http://www.zapfilmes.com
  • Lennert Daniëls
    December 15, 2015 at 2:25 pm
    Cassius: Unfortunately, the Altcode didn’t work either… Same goes for copying the text from other applications.
    Dave: Text needs to be editable, can’t go with stills. Also way to cumbersome, considering I need 100-200 perfectly aligned text layers.
    Could someone test this problem in AE CC? I’d like to know if Adobe fixed it. Some fonts to test: “Impact Label” and “Top Secret“.
    I’m now resorting to using a nasty combination of parenting and expressions to create shape layers around the text. A real brain challenge to set up, but sort of semi-automatic when it’s finally working.
    This workaround also doubles my layer count, since I need one shape layer for every text layer. I’m estimating it’ll end up being about 400 layers total.
  • Kalleheikki Kannisto
    December 15, 2015 at 2:45 pm
    Same issue in CC2015.
    A relatively lame workaround idea: Make two characters that don’t have any overlapping parts (such as . and +) and use negative tracking value to place them on top of each other. Select this pair copy it and paste it wherever you need a space character.
  • Lennert Daniëls
    December 15, 2015 at 3:13 pm
    @Kalle Kanisto: That’s actually a fairly good workaround. It sparked an even easier idea given the software I have access to:
    I could use my font editor to remap the space character to some character that I don’t use, and perform a find and replace all” script within After Effects.
    Thanks to all! 🙂
    Reported to Adobe, hopefully they take it seriously.
