Activity Forums Adobe After Effects Space Character in Text Layer
  • Space Character in Text Layer
    Posted by Arturo Moreno reyes on January 17, 2012 at 6:14 pm
    I’ve trying to use a Negative Character Type Set similar to this one to create a dynamic text box easily updated by a script. But After Effects doesn’t understand the “space character” (UFT-0020) as is it is in the type character set, I just get and empty transparent space.
    Does anybody knows a way to turn around this issue? I’ve resolved the problem replacing my underscore sign by a block in my .TTF but it means that I have to be sure no one insert a space in the .txt used as input for the script. It would be easier and reliable if I found a way to make After Effects recognize my TTF space character!
    Thanks for any answer.
    Evan Abrams replied 14 years, 7 months ago 2 Members · 1 Reply
