Activity Forums DVD Authoring SP AUTHORING with 4.1
  • SP AUTHORING with 4.1
    Posted by John O’brien on August 17, 2006 at 7:14 pm
    Have just completed burning a couple of test discs using both quicktime and mp2 files (produced by Squeeze4/1). The squeeze files look much better just FYI. Do you think upgrading to something like digigami would make another incremental improvement over the sorenson version?
    also- I continue to have some set top compatibility issues with an old Phillips and newer Sanyo player. Discs play fine in a inexpensive Memorex. I think the following warnings produced during the burn by SP might have something to do with this:
    Warning: The file
    Eric Pautsch replied 20 years, 1 month ago 2 Members · 5 Replies
  • Eric Pautsch
    August 17, 2006 at 8:23 pm
    These are just warning DVDSP gives when doing a build. Just cuirius – Whats in track 1 of your project. Im kinda confused why it saying its not going to inluse those VOB files in your final buuild?
  • John O’brien
    August 17, 2006 at 9:42 pm
    ah….that’s it! I created a button but ended up losiing track of it while learning the graphics overlays etc….that’s why I got those warnings. Don’t suppose it could account for the decrease in compatibility (sanyo set top) do you?
    J.
  • Eric Pautsch
    August 17, 2006 at 9:49 pm
    No…But what is your bitrate? Did you use AC3 Audio in your title? These are the two most common factors that effect compatibilty
  • John O’brien
    August 17, 2006 at 9:53 pm
    I boosted the bitrate to 7.1 (I think ) and used an MP3 file in the title loop.
    thanks for your help here.
    J.
  • Eric Pautsch
    August 17, 2006 at 10:07 pm
    It all depends on the length of your titles but under 7mb/s is always smart. Get rid of that Mp3 file for sure and transcode it to AC3
