Activity Forums Sony Cameras SP 1080/24p FCP Sequence Settings?
  • SP 1080/24p FCP Sequence Settings?
    Posted by Peter Chambers on May 31, 2011 at 2:58 pm
    I’ve screwed up in the past and I don’t want to screw up again…
    What sequence settings do I choose in FCP under ‘Easy Setup’? Is it still XDCAM EX 1080p24 VBR or CBR OR is this an HDV setting?!
    Brent Dunn replied 15 years, 3 months ago 4 Members · 4 Replies
  • Michael Palmer
    May 31, 2011 at 3:16 pm
    SP is HDV and it is CBR for 25Mbps constant bit rate
    HQ is the EX codec, 35Mbps VBR, variable bit rate
    Good Luck
    Michael Palmer
  • Peter Chambers
    May 31, 2011 at 3:19 pm
    Hey thanks…I think I figured it out — just matched the specs in XDCAM Transfer tool and found indeed that I shot HDV, 1440×1080 60i.
    Thanks for the quick reply.
  • Craig Seeman
    May 31, 2011 at 3:22 pm
    If you create a new sequence and drop a clip on it, FCP will ask if you’d like it to match the settings. Answer affirmative. Then you can examine the sequence settings and see what FCP has chosen.
    Generally there’s little reason to shoot SP mode (there are a few but I’d consider those exceptional cases).
  • Brent Dunn
    May 31, 2011 at 5:58 pm
    As previously stated, you can just drop your footage on the timeline and Final Cut will make the settings for you. So don’t worry about all the settings.
    Also, if you ever shoot with different cameras, different codecs, it’s better to convert everything to prores first, or drop you preferred codec on the timeline and see what happens with the rest of the alternative clips.
    Brent Dunn
    Owner / Director / Editor
    DunnRight Films
    DunnRight Video.com
    Video Marketing Toolbox.net
    Sony EX-1,
    Canon 5D Mark II
    Canon 7D
    Mac Pro Tower, Quad Core,
    with Final Cut Studio
    HP i7 Quad laptop
    Adobe CS-5 Production Suite
