Activity › Forums › Adobe After Effects Expressions › sourcetext: two expressions work well alone, but not together
  • sourcetext: two expressions work well alone, but not together
    Posted by Matthias Schwarz on April 11, 2024 at 12:03 pm
    Hello dear fellows,
    I wrote two lines of code for a source text:
    var txt = value;
    txt.trim(); //removes whitespaces in front of text
    txt.substr(0/37);//limits the string to 37 signs
    Both expressions do what they should do when applied alone, but when I put them together,
    the trim-expression seems not to function- whitespaces in front will not be cutted off. I tried to change to order of the two line as a test, but I still have no clue why does not work properly. I used the clamp-expression in an other situation, but I guess this is a wrong way. Does anyone have an idea to put them together or have a different solution? Thanks you so much!
    Yours, Matthias
    Brie Clayton replied 2 years, 5 months ago 3 Members · 3 Replies
  • Tom Morton
    April 11, 2024 at 12:14 pm
    you’ve got the syntax wrong, each expression works fine on it’s own, but they RETURN a value, they don’t modify the existing value.
    var txt = value;
    txt.trim(); // removes whitespaces in front of text and returns the value - doesn't change the value of "txt" variable
    txt.substr(0/37);//limits the ORIGINAL string to 37 signs and returns it again. Expressions uses this as the last returned value
    Therefore you need to do something like this:
    var txt = value;
    txt = txt.trim(); //removes whitespaces in front of text
    txt = txt.substr(0/37); //limits the string to 37 signs
    txt;
    each expression will now update the value of the “txt” variable. hope that helps!
  • Matthias Schwarz
    April 11, 2024 at 1:30 pm
    Yes, it works! Thank you so much for that help! It´s just mean that the expressions works seperately..I need to code for work and it´s so long ago that I did this. The brain is a sieve…or more precise,
    my brain 🤣
    Yours, Matthias
  • Brie Clayton
    April 11, 2024 at 2:31 pm
    Thank you for solving this, Tom!
