Activity Forums Adobe After Effects Expressions sourceText is changing paragraph alignment
  • sourceText is changing paragraph alignment
    Posted by Mike Giannamore on June 11, 2024 at 2:39 am
    I’m trying to use the text from one left aligned text box to autofill the text only into a separate right aligned text box. sourceText is forcing the text in the right aligned box to the left…any ideas how get around this?
    Mike Giannamore replied 2 years, 2 months ago 3 Members · 4 Replies
  • Dan Ebberts
    June 11, 2024 at 3:50 am
    I’m curious how you have things set up. I just ran a test, grabbing the source text from a left-aligned text box into a right-aligned text box and only the text is effected, not the paragraph alignment, using this simple expression:
    thisComp.layer("left aligned").text.sourceText
  • Mike Giannamore
    June 11, 2024 at 2:38 pm
    Hey Dan – that is exactly how I did it too. It has worked for me in the past, so I’m kind of stumped.
  • Adam Greenberg
    June 11, 2024 at 3:35 pm
    can you post your project ( without source files )
  • Mike Giannamore
    June 12, 2024 at 3:49 pm
    I was able to solve the problem.
    Unfortunately, there was some glitch with the text box, and when I made a new one!
