Activity › Forums › Adobe After Effects Expressions › sourcerectattime not working for a specific time
  • sourcerectattime not working for a specific time
    Posted by Adam Greenberg on May 6, 2021 at 6:14 pm
    Hi, I have an expression that is working perfectly except for the fact that my title is animated in at the beginning ( in scale, position, and blur ). I thought I correctly identified the time to be 2 seconds so that any animation before or after would be disregarded, but its not working. I cannot figure out my error. Thanks for any help.
    Adam
    L = thisComp.layer(“TITLE”);
    M = thisComp.layer(“DATE”);
    rect = L.sourceRectAtTime(2,true);
    rv = M.sourceRectAtTime(2,true);
    x = L.toComp([rect.left+rect.width,0])[0];
    y = M.toComp([rv.left+rv.width,0])[0];
    xclamp=clamp(x,545.70,2000);
    yclamp=clamp(y,545.70,2000);
    if (x>y) xclamp+gap;
    else yclamp+gap
    Adam Greenberg replied 5 years, 4 months ago 4 Members · 8 Replies
  • 8 Replies
  • Adam Greenberg
    May 6, 2021 at 6:52 pm
    Sorry. First line was missing.
    gap=30;
  • Andrei Popa
    May 7, 2021 at 6:49 am
    Try to use rect = L.sourceRectAtTime(L.sourceTime(2),true); I had the same problem if the layer was moved forward or backward in the timeline.
  • Adam Greenberg
    May 7, 2021 at 3:47 pm
    Hmm. It’s not working. It’s still animated
  • Adam Greenberg
    May 7, 2021 at 3:52 pm
    I tested something. I added a new variable s with
    S=thisComp.layer(“test”).marker.key(“1”).time;
    I Tested the value at s and it is constant.
    but when I replace 2 with s in the expression, it still doesn’t work. It’s still animating the value. So the problem must be the way L is defined. Can I make L look at the title layer but only at a specific time. I tried to write it and rewrite it and I cannot figure it out.
    There must be a way for me to define L as this comp layer title but only at time s.
    Thanks.
  • Tomas Bumbulevičius
    May 7, 2021 at 5:01 pm
    Just an idea – see if inPoint of a layer you are timing to, matches the start time of composition. If not – try to take that difference into account .
  • Adam Greenberg
    May 7, 2021 at 5:22 pm
    I was thinking that also, until I replaced 2 with 200 and got the exact same result which means the time part of my expression is not affecting it at all.
    I can only guess that the definition of L needs a fixed time associated with it because even thought rect is well defined, the L must be looking at the text layer at every frame. It’s so frustrating knowing that the logic is there but I’m missing a command that I dont yet understand. some sort of value at time. I guess in the meantime I will duplicate my text layers, mute them, expression them to the source text of the real layers, remove all key frames from them, and add a correction slider in case one day a user goes in and plays with the character settings of that layer which would change the math a little.
  • Dan Ebberts
    May 8, 2021 at 12:19 am
    Animating the position or scale shouldn’t affect sourceRectAtTime(). What will affect your result though, is the time parameter of toComp(). See if doing it this way helps:
    x = L.toComp([rect.left+rect.width,0],2)[0];
    and
    y = M.toComp([rv.left+rv.width,0],2)[0];
  • Adam Greenberg
    May 10, 2021 at 2:07 pm
    Thanks so much Dan. I had no idea there was a time parameter in the tocomp. Makes total sense once you know that, and impossible to solve if you don’t.
    Have a great week. Thanks again.
