Activity › Forums › Adobe After Effects Expressions › sourceRect text layers which play off each other.
  • sourceRect text layers which play off each other.
    Posted by Chris Meadmore on July 2, 2019 at 9:41 am
    I’m using sourceRect.time to scale a text layer to a specific width. Works great.
    Now I have 2 layers which have the same expression applied and I’m trying to rig them off each other. So:
    Layer A scales to designated width unless Layer B is smaller in which case follow that.
    I’ve almost got it working with one layer, it scales itself depending on length but also monitors the other layer and adjusts accordingly. When I apply this same expression to the other layer it doesn’t work.
    Is there a way to do this without introducing extra layers / Nuls?
    Thanks for any help! Kinda urgent 😀
    textwidth = thisLayer.sourceRectAtTime().width;
    s = 100*1700/textwidth;
    b = thisComp.layer("Layer A").transform.scale;
    if(s < 100) [s,s] else b;
    Chris Meadmore replied 7 years, 2 months ago 3 Members · 6 Replies
  • Chris Meadmore
    July 2, 2019 at 9:51 am
    Oops… think I solved it on my own. Just needed a smoke break!
    a = thisLayer.sourceRectAtTime().width;
    b = thisComp.layer("Layer A").sourceRectAtTime().width;
    c = 100*1700/a;
    d = 100*1700/b;
    if(a > b) [c,c] else [d,d];
  • Chris Meadmore
    July 2, 2019 at 9:56 am
    Never mind, still not solved.
    The layers are playing off each other perfectly but I need to cap them at 100% so they don’t scale beyond that.
  • Scott Mcgee
    July 2, 2019 at 10:20 am
    There’s probably a better way.
    You can clamp your scale to not go above 100 for example.
    s = clamp(c,0,100);
    [s,s]
  • Chris Meadmore
    July 2, 2019 at 11:17 am
    Thanks Scott!
    I’ve brought a coder into the mix and he produced the below expression which worked perfectly although we’re now struggling with trying to apply it to 3 layers and find the max value from them.
    Any ideas how to do this? Thanks so much for the help!
    Layer1Width = thisComp.layer("LINE_01").sourceRectAtTime().width;
    Layer2Width = thisComp.layer("LINE_02").sourceRectAtTime().width;
    Layer1Ratio = 100 * 1700 / Layer1Width;
    Layer2Ratio = 100 * 1700 / Layer2Width;
    Layer1Ratio = Layer1Ratio > 100 ? 100 : Layer1Ratio;
    Layer2Ratio = Layer2Ratio > 100 ? 100 : Layer2Ratio;
    if(Layer1Width > Layer2Width ) [Layer1Ratio, Layer1Ratio] else [Layer2Ratio, Layer2Ratio];
  • Andrei Popa
    July 2, 2019 at 11:32 am
    So you try to go for the largest layer, but not over 100?
    Layer3Width = thisComp.layer("LINE_03").sourceRectAtTime().width;
    LayerRatio = 100 * 1700 /Math.max( Layer1Width, Layer2Width, Layer3Width);
    (LayerRatio<100) ? [LayerRatio, LayerRatio] : [100,100];
    You can put however many layers you wish.
    Andrei
    My Envato portfolio.
  • Chris Meadmore
    July 2, 2019 at 11:53 am
    That is PERFECT!
    Thank you
