Activity › Forums › Adobe Premiere Pro › Source/Program not matchin up
  • Source/Program not matchin up
    Posted by Andrew Ousley on July 13, 2011 at 4:18 pm
    I know this has been discussed on here before and I see everyone has been please with their answers, yet no one has spelled out (for a noob like me) how to get the source monitor ratio the same as the Program monitor ratio. I am using CS4 and the program monitor looks zoomed and fuzzy and I hate it! can someone please help?
    Alex Udell replied 15 years, 2 months ago 2 Members · 1 Reply
  • Alex Udell
    July 13, 2011 at 5:18 pm
    It’s likely that your seqeuence is not the same setting as you source material.
    try this….
    take a source clip and drag it down to the new Items button at the bottom of the project panel.
    this will make a sequence that is the same setting as the source….
    then see if if your monitors match.
    BEYOND THIS…its important to understand that your sequence needs to be set up to give you a clear path to the type of material you will ultimately be delivering.
    but that’s a longer conversation….
    Alex
