Activity Forums Adobe Premiere Pro Source Track Indicator/Patch Toggle disappears from my project. PremierePro CC 2017
  • Source Track Indicator/Patch Toggle disappears from my project. PremierePro CC 2017
    Posted by Jan Du on November 13, 2017 at 3:00 pm
    Hi Guys,
    Okay, so I can’t seem to toggle the source track indicator labeled V1(depending on the video track). It is used to toggle the video track that you’d like to paste a clip to. In my case, to activate V1 to cut my MultiCam sequence. I have scanned my toolkit and preferences to see if it is disabled. What is also strange is that issue does not occur in other projects that I have done without MultiCam.
    To add, I have recently migrated to another workstation and updated Premier from 2015 to 2017.
    Any help would be dearly appreciated.
    Ann Foo replied 8 years, 10 months ago 2 Members · 1 Reply
  • Ann Foo
    November 14, 2017 at 4:54 am
    Source track indicator (V1) will disappear if you don’t have any V1 media in your source window….
    So considering you’re trying to edit with a muticam sequence… perhaps your locator is at a part of the multicam sequence where there is no V1, (only V2 and/or sound). Try scrolling to a bit in the multicam sequence where there is V1 media. Or, load up a video only track into your source monitor and see if your V1 toggle comes on.
