Activity › Forums › Adobe Premiere Pro › Source timecode in CS6
  • Source timecode in CS6
    Posted by Gabriel Regalbuto on June 4, 2012 at 9:43 pm
    Is there a way I can view the source timecode at my CTI? FCP allows this in the program monitor, and 5.5 would provide this in the info panel. CS6 doesn’t seem to do this, unless I’m missing something.
    FC7 CS5.5
    MacPro 8x
    5drive eSATA stripe
    Gabriel Regalbuto replied 14 years, 3 months ago 5 Members · 8 Replies
  • 8 Replies
  • Kevin Monahan
    June 4, 2012 at 11:43 pm
    You can see the Source TC in the Source Monitor with a quick matchframe. Gang the monitors to have both running at the same time. Enable that in the panel menu.
    If that doesn’t float your boat, make a feature request: https://www.adobe.com/go/wish
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Alex Udell
    June 5, 2012 at 2:55 am
    Isn’t this available in the info panel?
    Alex
  • Gabriel Regalbuto
    June 5, 2012 at 6:55 pm
    No longer…
    FC7 CS5.5
    MacPro 8x
    5drive eSATA stripe
  • Tero Ahlfors
    June 6, 2012 at 6:54 am
    CS6 has pretty much identical info panel as 5.5. I can see every video and audio track timecodes in there.
  • Gabriel Regalbuto
    June 6, 2012 at 5:13 pm
    If I select a clip I get start, end, duration, etc. I get nothing about where I’m at with my CTI. The only way I can find out where I’m at in my source is to match frame, and then, obviously, only one track at a time.
    FC7 CS5.5
    MacPro 8x
    5drive eSATA stripe
  • Atticus Culver-rease
    June 6, 2012 at 7:45 pm
    You can also go to Window>Timecode which opens a new panel that displays timecode, and then there’s a pulldown menu in the top right corner where you can change it from displaying your timeline timecode to source timecode from any video or audio track. But it’s still only displays one track at a time, and you’ve gotta deal with having another window parked somewhere.
  • Kevin Monahan
    June 7, 2012 at 7:05 pm
    That’s correct, and it’s new in CS6. If you want more than one track displayed, you can make a feature request: https://www.adobe.com/go/wish
    More info here: View timecode in the Timecode panel.
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
  • Gabriel Regalbuto
    June 7, 2012 at 10:55 pm
    The timecode viewer is another thing I’ve checked off my wish list – very helpful with a producer over my shoulder. Not sure why they pulled that info out of the info panel, which doesn’t display anything without a clip selected anymore.
    I gotta say, it does feel like they are trying, no? Such a nice change from Apple there.
    FC7 CS5.5
    MacPro 8x
    5drive eSATA stripe
