Activity Forums Apple Final Cut Pro Legacy Source Timecode in canvas
  • Source Timecode in canvas
    Posted by Bryan Arnold on October 3, 2005 at 4:00 pm
    I was wondering if anyone had any ideas why I cannot see the clip’s source timecode in the canvas. The timecode spot in the top right hand corner shows the main timeline timecode. When I right click on the box and choose source timecode, nothing changes, even when I select the other option clip time. I get the source clip timecode in an overlay, but I wanted to see it in the canvas timecode spot.
    Any ideas?
    Thanks for any help!
    Bryan Arnold replied 20 years, 11 months ago 2 Members · 4 Replies
  • Jerry Hofmann
    October 4, 2005 at 1:00 am
    Use the overlay… it’s the only way this works as far as I know… what the source TC display refers to is not the original code of the source clip (it has to do with fps material that isn’t the same as the sequence setting’s fps… read about it in the manual. type “source Time” in the search box in FCP help…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Bryan Arnold
    October 4, 2005 at 2:14 pm
    Thanks, that is what I have been doing, it would be nice to type in the source clip timecode in the canvas though…
  • Jerry Hofmann
    October 5, 2005 at 11:34 am
    You could match frame a clip… then the source TC would be in the Viewer.
    Jerry
  • Bryan Arnold
    October 5, 2005 at 1:32 pm
    Thanks, I’ll try that.
