Activity Forums Adobe Premiere Pro Source timecode burn in???
  • Source timecode burn in???
    Posted by Bruce Schultz on April 30, 2009 at 10:38 pm
    Is there a way to burn in source timecode from original clips for export to a proxy sized mov file? I want to send some smaller version of the clips to someone on DVD and have them make notes that reflect the original/source timecode rather than the timeline window numbers.
    Paul Del vecchio replied 17 years, 4 months ago 3 Members · 3 Replies
  • Jon Barrie
    April 30, 2009 at 11:27 pm
    Before you do anything, make a duplicate of the seq with all footage dropped in back to back. and name it BITC reference (tape name?)
    find the ‘timecode’ effect in the effects panel search box, add it to the first clip in the timeline.
    set up the effects properties in the effect controls panel.
    change timecode source to: media
    make sure the time display is set correctly too. (it should automatically correct itself if it was wrong, but check it anyway)
    copy the clip with the effect on it. Select all the other clips and paste attributes.
    Check out this tutorial:
    https://www.youtube.com/watch?v=xMx0YIZGN1Q&feature=channel_page
    hope it helps, with other uses of the BITC timecode effect.
    – Jon 😉
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Bruce Schultz
    May 1, 2009 at 5:02 pm
    Perfect Jon, exactly what I was looking for.
    Thanks loads
    Bruce Schultz
    F900R/EX-1
    LA-based IATSE 600
  • Paul Del vecchio
    May 1, 2009 at 7:42 pm
    Great tutorial, Jon!
    You know, I actually didn’t know that you could get the clip timecode. How careless of me! haha
    Thanks for that! Awesome tutorial!
    Paul Del Vecchio – Director
    https://www.PaulDV.com
