Activity Forums Adobe Premiere Pro Source time In and Out Point
  • Source time In and Out Point
    Posted by Joe Bodego on February 27, 2018 at 9:05 am
    Hello great people, i have a question, when i do an in and out in the source, is there a way to see the actual time of the in and out points ? I know i can check when i add it to the timeline but i would like to for example do 3 seconds and know its 3 seconds before it hits the timeline.
    Greg Janza replied 8 years, 5 months ago 4 Members · 7 Replies
  • 7 Replies
  • Tero Ahlfors
    February 27, 2018 at 9:14 am
    [Joe Bodego] ” is there a way to see the actual time of the in and out points ?”
    Yes.
  • Joe Bodego
    February 27, 2018 at 9:20 am
    Thank you so much, i should have caught that. Ok lets say you want to add 5 seconds, is there a way to specify 5 seconds from the top?
  • Tero Ahlfors
    February 27, 2018 at 9:39 am
    For example if you’re cutting 25fps footage you could do it in two ways:
    -Numpad +, then 424, enter and mark out.
    Or:
    -Numpad +, then 500, enter, step back one frame and mark out. This is because Premiere (like pretty much every other NLE) uses inclusive out points so the frame you’re parked on is included.
  • Joe Bodego
    February 27, 2018 at 9:51 am
    Thank u that was helpful
  • Tero Ahlfors
    February 27, 2018 at 10:04 am
    You can also use the numpad + and duration command in the sequence. If you have nothing selected you can move the playhead with it or if you have clips selected you can move them around the required frame amount.
  • Herb Sevush
    March 2, 2018 at 4:12 pm
    [Tero Ahlfors] “This is because Premiere (like pretty much every other NLE) uses inclusive out points so the frame you’re parked on is included.”
    As an aside, this statement, while true, drives me crazy. The inclusive out point, while intuitive, is a major PITA. The exclusive out point, while totally non-intuitive, is mathematically sounder and infinitely more useful. It is not intuitive that the Earth revolves around the sun, but it is both true and useful information to know.
    Herb Sevush
    Zebra Productions
    nothin\’ attached to nothin\’
    \”Deciding the spine is the process of editing\” F. Bieberkopf
  • Greg Janza
    March 2, 2018 at 5:27 pm
    [Herb Sevush] “As an aside, this statement, while true, drives me crazy.”
    Ditto.
    I Hate Television. I Hate It As Much As Peanuts. But I Can’t Stop Eating Peanuts.
    – Orson Welles
