Activity Forums Adobe After Effects Expressions Source Text from Text File
  • Source Text from Text File
    Posted by Mark Walczak on March 18, 2010 at 9:30 pm
    Hi everyone,
    So, I realize that this topic has been discusses at great length on several forums (including the Cow), but I have been searching tirelessly and without success for my own application. Here’s what I’m trying to do:
    Feed a text layer a text file and have it sample one word from the document for every frame of video.
    I realize that many types of “text file to AE” questions deal with lower thirds, and generating comps, but this isn’t quite what I’m going for. I should mention that I’m on a Mac, in case that makes any difference, and I am running AE CS4.
    Thank you in advance!
    https://vimeo.com/explosivegraffix
    Peter Auboeck replied 15 years, 6 months ago 5 Members · 16 Replies
  • 16 Replies
  • Dan Ebberts
    March 18, 2010 at 11:00 pm
    With this text file:
    txt = “one two three four five six seven eight nine ten”;
    This expression displays a different word on each frame:
    myPath = “/C/Temp/text_test.txt”;
    try{
    $.evalFile (myPath);
    mySplit = txt.split(” “);
    f = timeToFrames()
    mySplit[Math.min(f,mySplit.length-1)]
    }catch (err){
    “file not found”
    Of course your file path will be different, and you may want to use something other than spaces to delimit your words. This works for CS4 — if you have CS3 you’ll have to use the #include method.
    Dan
  • Mark Walczak
    March 19, 2010 at 2:00 pm
    Dan, you are my hero!
    Thanks again for another amazing expression!
  • Brian Byrne
    April 18, 2010 at 11:12 pm
    I have a .txt file with almost 1800 names (first and last) separated by a line break. I’d like to split all names up into single frames of one text layer for use as a sprite in Particular 2.0. I’m able to use what you have here as a good starting point, but I’m afraid I don’t know enough about expressions. I’ll keep crunching through the expressions documentation, but if anyone can provide suggestions it would be greatly appreciated.
  • Dan Ebberts
    April 19, 2010 at 3:00 am
    In my opinion, you’d be much better off using a script for this. The script would read each line of the text file and create a new keyframed value for the source text at each frame.
    Alternatively, to get the expression to work, you’d have to alter your text file so that each line is a valid expression statement, like this:
    txt = [];
    txt[0] = “your first word”;
    txt[1] = “your second word”;
    etc.
    Then you could use a source text expression that assigns a new word at each frame. like this (not tested):
    f = timeToFrames();
    txt[Math.min(f,txt.length-1)]
    At each frame, the expression has to read in the enitire 1800 line text file. If you use a script rather than the expression, you only have to read the text file once. Of course, it’s a bit of work to create such a script.
    Dan
  • Tom Granberg
    May 12, 2010 at 8:30 pm
    Hi Dan
    I am using Cs3, windows, and obviously this expression doesnt quiete work.
    What changes to the expression do I need?
    Path = "I:code01.txt";
    try{
    $.evalFile (Path);
    eval(Textflow);
    }catch (err){
    "not found"
  • Dan Ebberts
    May 12, 2010 at 10:21 pm
    CS3 is going to need something like this for the first line:
    #include ‘/I/code01.txt’;
    Beyond that, it’s hard to say without knowing what’s in the text file and what you’re trying to do.
    Dan
  • Tom Granberg
    May 12, 2010 at 11:51 pm
    Just trying to get a text layer to accept a txt file.
    Do I need some formatting on the slashes?
    #include ‘//I//code01.txt’;
    I running win7
    Thank you so much.
    T
  • Dan Ebberts
    May 13, 2010 at 2:16 am
    The text layer has to contain executable javascript statements. For example if I have a text file (named “text_test.txt” on my c drive in the temp folder) containing this text:
    I can add this expression (CS3) to a text layer:
    #include ‘/C/temp/text_test.txt’
    txt
    and the text layer will display this:
    I hope that helps.
    Dan
  • Tom Granberg
    May 13, 2010 at 8:17 pm
    I wish it worked, I am sure it does on Mac platforms.
    I cant for the world of me get it to work, I keep getting file/folder not found errors.
    I am using win7 with CS3 if that helps.
    My path is as follows:
    C:\Users\Renderbrandt\Documents\text\doce01.txt
    Is there a special way I need to format the path?
    Thanks iun advance, I wish I wasnt shuch an pia…
    Tom aka Renderbrandt
  • Dan Ebberts
    May 13, 2010 at 9:00 pm
    Please try:
    /C/Users/Renderbrandt/Documents/text/doce01.txt
    Dan
