Activity › Forums › Adobe After Effects Expressions › Source text for displaying thisLayer.sourceRectAtTime(time).width
  • Source text for displaying thisLayer.sourceRectAtTime(time).width
    Posted by Geoff Vane on October 12, 2020 at 5:02 pm
    Stupid expression problems can cause hours in delay.
    I have no means of reading variables other than putting them into a source text with an expression.
    These here work fine as a source text expression:
    thisLayer.name
    thisLayer.position or thisLayer.position[0] if you wanna go specific.
    Why doesn’t this work:
    Whatever I try, I can’t get the source text to reveal this value. It just switches back to the default source text without any error.
    This seriously delays my debugging of a coding error.
    Help!
    Geoff Vane replied 5 years, 11 months ago 1 Member · 1 Reply
  • Geoff Vane
    October 12, 2020 at 6:17 pm
    I found the culprit: a text layer can’t examine its own size and publish that with its source text property.
    This would be something of a recursive problem.
    When I let the text layer take another layer its size, it could publish that.
    This way I found out my problem sat in another nice nasty: the update of the if-then structure.
    If-then-else is now a must.
