Activity › Forums › Adobe After Effects Expressions › Source Text Expressions
  • Source Text Expressions
    Posted by Chris Taylor on October 12, 2021 at 5:09 pm
    Hi all,
    I am trying to combine several text-specific expressions, but I can only get 1 to work.
    Depending on the layout, the 2nd one will always override the first.
    I have tried the if/else expression and the substring, but none seem to work together.
    The first expression is a character limit.
    The second is a “source text style”, driven by sliders and checkboxes.
    I don’t know if I am missing something or if there is an issue with them working together.
    Any guidance on this would be very helpful.
    l = text.sourceText.length;
    if (l>25) {
    “MAX LENGTH EXCEEDED”
    } else {
    text.sourceText;
    var array=[
    “Worker-ExtraBold”,
    “Worker-Regular”,
    text.sourceText.style
    .setFontSize(thisComp.layer(“CTRL”).effect(“Font Size”)(“Slider”))
    .setFont(array[thisComp.layer(“CTRL”).effect(“Font Select”)(“Slider”)])
    Chris Taylor replied 4 years, 11 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 12, 2021 at 5:23 pm
    I haven’t tested this, but I think you just need to save your text in a variable and then use .setText() at the end of your expression, like this:
    if (l>25) {
    txt = "MAX LENGTH EXCEEDED"
    } else {
    txt = text.sourceText;
    var array=[
    "Worker-ExtraBold",
    "Worker-Regular",
    .setFontSize(thisComp.layer("CTRL").effect("Font Size")("Slider"))
    .setFont(array[thisComp.layer("CTRL").effect("Font Select")("Slider")])
    .setText(txt)
  • Chris Taylor
    October 13, 2021 at 7:59 am
    Yep that worked perfectly
