Activity Forums Adobe After Effects Expressions Source Text Expression. Write on effect justified right. SourceRectAtTime Box
  • Source Text Expression. Write on effect justified right. SourceRectAtTime Box
    Posted by Gerald mark Soto on November 30, 2017 at 3:50 pm
    I have been trying to figure out how to make type write on via source text. The reason i want to use source text rather then just a simple opacity & position animator is because I also want to apply the expression to a shape layer to perform the (SourceRectAtTime) so i can have a box the same size as the type. But as the type writes on it also gets bigger. And I want the type justified right.
    Are there source Text expression that can have a sentence write on? maybe it can be controlled via a slider so each word is an index number?
    Help.
    Oscar Rodriguez replied 6 years, 1 month ago 3 Members · 8 Replies
  • 8 Replies
  • Dan Ebberts
    November 30, 2017 at 5:25 pm
    Something like this maybe:
    s = effect("Slider Control")("Slider").value;
    str = "";
    txt = value.split(" ");
    for (i = 0; i < Math.min(txt.length,s); i++){
    str += (i > 0 ? " " : "") + txt[i];
    str
    Dan
  • Gerald mark Soto
    November 30, 2017 at 5:38 pm
    BOOM!! Thats it. How about having the ability to have the word as it appears with an opacity of 30% then when the next word appears its at 100%. So as each word appears it starts at 30% then becomes 100% after the next word appears. ????
  • Dan Ebberts
    November 30, 2017 at 7:13 pm
    Instead of having a source text expression, you could add an Opacity Animator (set the value to 0%), then add an Expression Selector and delete the Range Selector. On the Expression Selector, set Based On to Words, and add this expression for Amount:
    s = Math.round(effect("Slider Control")("Slider").value);
    if (textIndex == s)
    70
    else if (textIndex < s)
    0
    else
    100
    Dan
  • Gerald mark Soto
    November 30, 2017 at 9:06 pm
    But i need it to have a expression on the source text because I want a box layer using the SourceRectAtTime expression. The only way SourceRectAtTime works is based on Source text value. I need the size of the box to increase as the sentence pops on.
  • Gerald mark Soto
    November 30, 2017 at 9:09 pm
    Actually, i just combined them both and its doing exactly what i want. I think im good. thanks again señor. Your amazing.
  • Gerald mark Soto
    April 20, 2018 at 8:22 pm
    Hello Sir, New question on this expression. Currently the words pop on and opacity pops from 30 to 100%. which is great but a new situation has come up. Is it possible to not have the words pop on but actually have each word slide out instead and the transparency go from 0 to 100%. So it will just be a smooth animation of words being revealed. Is this possible? Thanks again Sir.
  • Oscar Rodriguez
    August 13, 2020 at 1:18 am
    Hi, is there a way to make the animation per character and not per word? Thanks!
  • Oscar Rodriguez
    August 13, 2020 at 1:54 am
    this works perfect for me, but i need to be per character not per word, is there a way to do it? thanks a lot, sorry to bother
    str = "";
    for (i = 0; i &lt; Math.min(txt.length,s); i++){
    str
