Activity Forums Adobe After Effects Expressions Source text alignment | Element3D
  • Source text alignment | Element3D
    Posted by Chris Zinner on April 30, 2016 at 1:45 pm
    working like crazy for an upcoming event i’ve run into another issue.
    I’m using a very simple slider control script to make a number count upwards from one value to another.
    Math.round(effect(“Slider Control”)(“Slider”))
    I want to extrude that number in Element3D which works fine.
    But as the numbers change the extruded typo jumps around even though i’m using a monospace font and the animated source text looks fine.
    I’ve come across this thread:
    https://www.videocopilot.net/forum/viewtopic.php?f=42&t=104640&start=0&hilit=#p331082
    The solution seems to be to create a bounding box by adding ‘ and , caracters and some spaces before and after the source text.
    “´ “+min + “:” + padZero(sec) +” ,”
    Can anybody show me how to edit the expression so that i can actually add those characters to the output?
    Thank’s!
    Math.round(effect("Slider Control")("Slider"))
    Chris Zinner replied 10 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    April 30, 2016 at 2:38 pm
    Like this maybe:
    n = Math.round(effect("Slider Control")("Slider"))
    "´ " + n + " ,"
    Dan
  • Chris Zinner
    May 12, 2016 at 3:59 pm
    It worked!
    Thank you very much and sorry for the late reply!
