Activity › Forums › DaVinci Resolve › Source side correction
Posted by Oliver Peters on July 10, 2012 at 12:11 pmPardon if this has been answered before or if I’m just missing something obvious. I have a single, flattened scene, which I sliced in FCP7. This was exported as an XML and then loaded into Resolve, which correctly sees all the “add edits” I made, so shots are separate. When I apply a correction it affects all clips at once. This appears to be a source-based correction, which is not what I want. I don’t find a preference setting to control this behavior. Suggestions? I have done this before with another project using Scene Detection and didn’t run into the same issue.
Oliver
Orlando, FL
http://www.oliverpeters.comOliver Peters replied 14 years, 2 months ago 4 Members · 10 Replies -
Pepijn Klijs
July 10, 2012 at 12:34 pmDo you see little red squares in your thumbnails on the resolve timeline?
Editor/Colorist, Amsterdam, The Netherlands
http://www.pepijnklijs.nl -
Pepijn Klijs
July 10, 2012 at 12:37 pmIf so, right click the thumbnails and choose ‘batch unlink’.
Good luck!
Oliver Peters
July 10, 2012 at 12:56 pm[Pepijn Klijs] “If so, right click the thumbnails and choose ‘batch unlink’.”
Yes, I do. Thanks. I’ll try that tonight when I get back to this project.
Cheers,
OliverOliver Peters Post Production Services, LLC
Orlando, FL
http://www.oliverpeters.com -
Dan Moran
July 10, 2012 at 1:58 pmIf you have any grades you want to preserve use batch copy instead of batch unlink. That will copy all the current grades to the clips and break the link.
Dan Moran
Colourist
Smoke & Mirrors: London
http://www.danmorancolor.com/blog -
Oliver Peters
July 10, 2012 at 10:57 pm[Pepijn Klijs] “Do you see little red squares in your thumbnails on the resolve timeline?”
This fixed the problem. Thanks.
– Oliver
Orlando, FL
Sascha Haber
July 11, 2012 at 7:12 amNow go and spend some time with the manual 🙂
If you had tried what Pepijn suggested, all your grading work would have been lost.A slice of color…
DaVinci 8.2.1 OSX 10.7.2
MacPro 5.1 2×2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+ICA Instructor
https://www.icolorist.com/Sascha.html -
Pepijn Klijs
July 11, 2012 at 7:33 amWhat grading work? I think he wrote that he couldn’t work that way. If all your shot get the same grade as the first one your doing, you can only loose one grade at max, so that’s why I gave that advice.
Sascha Haber
July 11, 2012 at 8:22 amWhen he had started grading the stuff, leaving the red ones connected , grading different shots and do Batch Unlink, all is lost.
Batch Unlink should ONLY be used before any work has done and frankly, i think it should be hidden from the tool palette, should have an additional warning or at least should be undo-able.
I did it once and it was very unpleasant to see everything go.A slice of color…
RAID0 8TB
Pepijn Klijs
July 11, 2012 at 9:27 amAgreed, it should get a warning.
But how can someone start grading when ALL of his shots are linked? He could only do one grade maximum.
Anyway, I do agree that batch copy is more safe!
Oliver Peters
July 11, 2012 at 12:09 pmCorrect. I had not started a grade yet, so the command was fine. The truth is that I haven’t gone super deep into Resolve yet as I am waiting for 9. I’ve only done a handful of smaller jobs. Still partial to Color, I guess. The Resolve UI layout isn’t really conducive for my home edit suite, which uses dual 20″ displays. I hope that 9 will address this.
Oliver
Orlando, FL
