Activity Forums Adobe Premiere Pro Source sequences Multicam Sequence Rendering
  • Source sequences Multicam Sequence Rendering
    Posted by Andy Ambrose on February 6, 2008 at 12:23 pm
    Hi Guys,
    Can anyone tell me, do you have to render the individual sequences (cam 1 cam 2 etc ) as well as the finished multicam sequence ?
    When exporting to Mpeg 2 from the final multicam sequence the encode is very ‘ghosted’ on the lateral movement ( my encoding settings are my usual ones I have used many times without a problem).
    Andy
    Todd Smaretsky replied 18 years, 7 months ago 3 Members · 2 Replies
  • Jon Barrie
    February 6, 2008 at 11:47 pm
    No you don’t need to render the original clips.
    Maybe you need to switch off the frame blend option on the clips (original sequence).
    – Jon 🙂
    How many editors does it take to change a light bulb?
  • Todd Smaretsky
    February 9, 2008 at 4:05 am
    I’d render. But as the previous post said – remove frame blend. The reason why rendering messes it up is because Premiere blends the frames when rendering.
    Hope this helps.
