Activity Forums Adobe After Effects Source layer lightness controller
  • Source layer lightness controller
    Posted by Alexandru Cirjaliu on October 21, 2017 at 12:55 pm
    Hello guys, i need some help, i don’t even know how to name it, but i am looking for a way to create a controller based on a *.mov lightness that can be linked with other layer.
    So lets say i have an optical flare pre-render with flicker, i want a plugin or expression that turns the lightness into a value slider, because i want to link other effects to this slider value so everything is connected and in flow.
    Motion Graphics artist
    Walter Soyka replied 8 years, 10 months ago 3 Members · 2 Replies
  • Brendon Murphy
    October 21, 2017 at 6:42 pm
    By “lightness”, do you mean transparency in this case?
    You could add a null to your comp and put a “slider control” effect on it. Twirl down the transparency setting on your flare. Alt+click the stopwatch, and then click-drag the little spiral icon to “pick whip” it to the control slider. You can now control the transparency of the flare with the slider.
    Brendon Murphy
    ________________
    Visual Effects
    http://www.brendonmurphy.net
  • Walter Soyka
    October 23, 2017 at 5:01 pm
    You can use the sampleImage() expression to get pixel values from footage.
    Check out this example — it’s really close to what you’re looking for:
    https://www.motionscript.com/design-guide/obscuration.html
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
