Activity › Forums › Adobe Encore DVD › Source is 1080p, do I export as m2v with lower field for standard DVD?
  • Source is 1080p, do I export as m2v with lower field for standard DVD?
    Posted by Chon Teck on September 22, 2014 at 4:38 pm
    Dear all,
    I’m using Premiere Pro CC and Encore CS6 but no dynamic link.
    Hence I’m planning to export my completed sequence as Mpeg2-DVD and then importing the m2v file into Encore for a PAL DVD.
    The original footage is shot in 1080p.
    So I’m guessing I should export the m2v in “lower field” as required by PAL DVD? Are there any issues I should take note of if this is the recommended option?
    Or do I export as progressive and then let Encore do the conversion? If so, what exactly do I have to do in Encore?
    If there’s a better solution, plese let me know.
    Thanks in advance!
    j
    Daniel Ludwig replied 11 years, 11 months ago 3 Members · 2 Replies
  • Jeff Pulera
    September 22, 2014 at 6:52 pm
    I work with NTSC video and commonly create Progressive MPEG-2 DVD files and use those in Encore, and they do not transcode, don’t see why you couldn’t do the same in a PAL environment.
    Jeff Pulera
    Safe Harbor Computers
  • Daniel Ludwig
    October 11, 2014 at 6:47 pm
    possible – same working with PAL as well. I wouldn´t use lower first – you can go progressive as well.
    danny
