Activity Forums Adobe After Effects Source framerate different from compositions framerate
  • Source framerate different from compositions framerate
    Posted by Trung Nguyen on October 22, 2012 at 8:23 pm
    Hello,
    I have a source footage that was shot using an iPhone 5. When I load it into CS5.5 (getting CS6 soon -don’t know if that matters), it has a 30fps. But all of my compositions (ie. gadgets for HUD) that I’ve previously worked on (just solids, shapes, particles, etc. -no footage) are 29.97 fps. Now, I want to create a new composition (MAIN comp) and put this iPhone5 footage (30fps) and all of my previous gadget compositions (29.97fps) into it. Which of these is recommended?
    1. Leave everything as is.
    2. Or interpret iPhone5 footage > Conform to 29.97? (Cons: audio maybe out of sync?)
    3. Or change ALL of my previous gadget compositions’ settings to 30fps?
    4. Or any other better method?
    The final rendered will be for Youtube and primarily view on a PC.
    Trung Nguyen replied 13 years, 10 months ago 62,905 Members · 1 Reply
  • Trung Nguyen
    October 23, 2012 at 7:12 pm
    Here’s the media info that Media Player Classic provided for the iPhone5 video:
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 64.6 MiB
    Duration : 32s 465ms
    Overall bit rate : 16.7 Mbps
    Recorded date : 2012-10-22T14:22:05-0500
    Encoded date : UTC 2012-10-22 19:22:05
    Tagged date : UTC 2012-10-22 19:27:25
    Writing application : 6.0
    Writing library : Apple QuickTime
    Model : iPhone 5
    Make : Apple
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 1 frame
    Format settings, GOP : M=1, N=30
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Source duration : 32s 495ms
    Bit rate : 16.6 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Rotation : 180°
    Frame rate mode : Variable
    Frame rate : 29.970 fps
    Minimum frame rate : 28.571 fps
    Maximum frame rate : 31.579 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.267
    Stream size : 64.2 MiB (99%)
    Source stream size : 64.3 MiB (100%)
    Title : Core Media Video
    Tagged date : UTC 2012-10-22 19:22:17
    Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format profile : LC
    Codec ID : 40
    Duration : 32s 463ms
    Source duration : 32s 508ms
    Bit rate mode : Constant
    Bit rate : 64.0 Kbps
    Channel(s) : 1 channel
    Channel positions : Front: C
    Sampling rate : 44.1 KHz
    Compression mode : Lossy
    Stream size : 249 KiB (0%)
    Source stream size : 249 KiB (0%)
    Title : Core Media Audio
    Apparently, it’s Variable framerate. But when I imported it into After Effects, it became 30 fps.
    So are you suggesting that I should make my MAIN comp as 30 fps, put the iPhone5 footage and my other 29.97 comps that I’ve previously worked on in there, and just work normally? Then at the end, render the whole thing as 29.97?
