Source file is smooth, preview and render is choppy…
I have a strange problem.
On one of my videos, source file playback is perfectly smooth, but for a few seconds in different parts of the video, the rendered video will be choppy (looks like it has a frame rate of 15 fps instead of 30 fps). The same sections of choppiness also occur in the Sony Vegas preview, so I doubt it’s related to bit rate.
I have disabled resampling and also tried turning off GPU acceleration, it did not help.
Project settings:
1920 x 1080
Field order: none (progressive)
PAR: 1.0000
Frame rate: 29.970
Pixel format: 8-bit
Full-resolution rendering quality: best
Motion blur type: gaussian
Deinterlace method: noneSource
Streams
Video: 00:14:19.035, 29.994 fps progressive, 1920x1080x12, AVC
Audio: 00:14:19.052, 48,000 Hz, Stereo, AACI thought maybe it was because the frame rates of project & file were off by 0.024, but that wasn’t the case.
