Activity Forums Adobe After Effects Source compression type is not supported
  • Source compression type is not supported
    Posted by Jerel Peterson on December 8, 2018 at 4:03 am
    I just updated to AE 2019 (version 16 build 235).
    But now many of my green-screen videos won’t load because it says the source compression type is not supported. I made these in a fairly old version of Premiere (CC6) using QuickTime Animation, 32-bit to get the transparency.
    Is there any workaround that will let me use these files? If not, how should I be exporting from within Premiere so that this new version of AE will accept them? I do have a CC license, so I have the new version of Premiere, but I’ve always found the more recent versions to be a bit confusing when it comes to exporting, so that’s why I’ve stayed with CC 6.
    Jerel Peterson replied 7 years, 8 months ago 1 Member · 1 Reply
  • Jerel Peterson
    December 12, 2018 at 8:38 am
    I did the same — I realized that there was an option to download previous versions, and I found that everything worked with 17. (I’m only an occasional hobbyist user of AE and Premiere, so I’m often befuddled by the updates)
