Activity Forums Avid Media Composer Source and Record Monitor issues
  • Source and Record Monitor issues
    Posted by Joseph Sierchio on May 3, 2013 at 2:49 pm
    My source and record monitors have moved under the top framing bar and I can’t grab them to move them back. Anyone have a fix for this? Refer to picture link below.
    James Beattie replied 13 years, 4 months ago 4 Members · 3 Replies
  • Michael Phillips
    May 3, 2013 at 4:20 pm
    Can you use the workspaces/layout and select Source/Record Editing and see if that brings it back into view?
    Michael
  • Timothy Miller
    May 4, 2013 at 1:21 pm
    Whatever the misplaced window, click on it to activate it or type its shortcut, in this case cmd 4, and then go to ‘windows’ menu and select fourth line i.e. ‘Home’ or shortcut cmd ‘ . This will replace the window in a less tricky position.
    Best,
    Timothy
  • James Beattie
    May 7, 2013 at 2:54 am
    I am sure you have this figured out, but maximize your window, then Select Composer window (source record), Then go under windows and choose home.
    Michael’s Idea of workspace windows should work as well.
    When in doubt, create new user settings. It is a dirty way to do it, but worth a try.
    James Beattie
    ACSR Elite/Avid ACI, Apple Certified Technician
    Consulting for Workflow and Digital Technologies at Comprehensive Technical Group
