soundwave material
I’m currently working on a project creating soundwaves and i’d quite like them to be green at the peaks and then go down to red in the troughs.
I was wondering if there is any way you can set up a material to achieve this, i was thinking you could maybe use a gradient that mapped vertically or something?
The waves are made from splines with a sweep nurb.
