Activity Forums Apple Final Cut Pro Legacy Soundtrack related FCP question
  • Soundtrack related FCP question
    Posted by Mike J. on June 24, 2005 at 7:53 pm
    Can the new Soundtrack compress and EXPAND the low end of audio to balance the highs and lows into on central sound db…basically so whispers and yells are the same volume?
    Mike
    The202 replied 21 years, 3 months ago 2 Members · 1 Reply
  • The202
    June 25, 2005 at 12:38 am
    Yes, SoundTrack Pro has several dynamic “effect” filters which should work well for what you want. Among those are an expander, a compressor and a “multipressor” as it’s called in STP. Filters can be applied “live” and adjusted during playback. STP utilizes a “non-destructive” action stack so you can toggle your filters on and off in almost any combination. I’ve used the multipressor a few times with good results.
