Activity › Forums › Apple Final Cut Pro Legacy › Soundtrack Pro/Export Multiple Clips from Multitrack STP Project
  • Soundtrack Pro/Export Multiple Clips from Multitrack STP Project
    Posted by Steve Smith on July 23, 2013 at 1:24 am
    I’ve got a an assemble edit in FCP that has about seventy wall-to-wall VO clips spotted in according to the vision. I need to shave about 10% off the project/sequence duration so I figured exporting the VO clips to STP and then time stretching (shrinking) them all across the board to be about 7% shorter would be a good move and from there I can tighten up the edits on the timeline.
    Can I export the individual clips back to FCP so that they all reappear as stand alone clips in the FCP sequence. So far I can only see how to export the VO back to FCP as one long flattened track giving me less flexibility.
    (Btw would also be helpful to know if there is a way of universally applying the time change to all the VO clips in STP at once rather than repeating the filter application for each and every clip).
    Much appreciated.
    Steve Smith
    Producer/Director/Editor
    Michael Gissing replied 13 years, 2 months ago 2 Members · 1 Reply
  • Michael Gissing
    July 23, 2013 at 1:58 am
    Export the whole track as one clip. Crunch the duration, reimport back into FCP and split back as individual clips if needed.
    That will be a lot quicker than doing time manipulation on each clip
