Activity › Forums › Apple Final Cut Pro Legacy › Soundtrack pro Audio Problem
  • Soundtrack pro Audio Problem
    Posted by Glenn Rogers on May 10, 2009 at 2:58 pm
    Guys i am trying to reduce background noise and need to (course instruction) to ‘send the file’ to Soundtrack Pro Audio File Project. While i click “send to” the Soundtrack Pro Audio File Project option does not appear as highlighted (as in, a choice i can make). However, Multitack Project and Soundtrack Pro Script do appear as highlighted in the menu.
    Any idea what changes i need to make to my settings to be able to get into Soundtrack Pro Audio?
    Pl help
    Glenn
    Glenn Rogers replied 17 years, 4 months ago 3 Members · 4 Replies
  • Paul Figgiani
    May 11, 2009 at 3:01 am
    Glenn,
    Select the audio track segment in the FCP timeline and Right Click on it.
    You’ll see the option that you are looking for
    -paul.
  • Glenn Rogers
    May 11, 2009 at 3:08 am
    Thanks Paul
    Doesnt work. The option i need is still not available.
    G
  • John Pale
    May 11, 2009 at 3:47 pm
    You need to be selecting the clip in a SEQUENCE. If you are selecting a clip in a bin or the viewer it won’t work…is that what you are doing ?
    If you want to do this with a clip not currently edited into a sequence, just open it directly in STP.
  • Glenn Rogers
    May 11, 2009 at 10:32 pm
    the clip IS in a sequence which is all ready now just for the audio part and i’m stuck. I also tried it on a different sequence and on seperate clips too – jut to check..same result.
    Was wondering..if Soundtrack Pro part of FCP software? Could it be that it may not have been installed while i was installing FCP? Is it ABSOLUTELY necessary (if yr experience) to you use Soundtrack Pro//can’t i get the job don by FCP Audio tools?
    Glenn
