Activity Forums VEGAS Pro SoundSoap–is it compatible?
  • SoundSoap–is it compatible?
    Posted by Carl Alessi on January 24, 2011 at 5:16 pm
    I recently upgraded to Vegas Pro 10, 64 bit. I tried to cover all my bases regarding plug-in compatability, but I forgot about one: Bias SoundSoap.
    Does anyone know if 1). There is a plug-in version of SoundSoap that will work with the 64 bit version of Vegas, or 2). if not, is there a substitute that I can use to achieve the same goal of filtering out background noise from my audio tracks?
    Thanks in advance,
    Carl
    John Rofrano replied 15 years, 7 months ago 3 Members · 5 Replies
  • John Rofrano
    January 24, 2011 at 6:53 pm
    [Carl Alessi] “1). There is a plug-in version of SoundSoap that will work with the 64 bit version of Vegas, “
    No, Sound Soap is 32-bit only. You could always use it with the 32-bit version of Vegas and then render the files and use the rendered files in the 64-bit version.
    [Carl Alessi] “2). if not, is there a substitute that I can use to achieve the same goal of filtering out background noise from my audio tracks?”
    iZotope RX. It’s a far superior noise remover to Sound Soap and it’s 64-bit compatible with Vegas.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Carl Alessi
    January 24, 2011 at 7:50 pm
    Thanks, John. I’ll give iZotrope a try.
    Carl
  • Carl Alessi
    January 24, 2011 at 10:52 pm
    John,
    Just one follow-up: do you know if I’ll require the standard version of iZotope RX, or the “Advanced” version to support Vegas 64 bit as a plug-in? I hope it’s the former, as the Advanced version is considerably more expensive.
  • Theo Van laar
    January 24, 2011 at 11:42 pm
    The standard version of Izotope RX2 works fine with my 64bits Vegas
    Theo
  • John Rofrano
    January 25, 2011 at 2:49 am
    Yea, the standard version of iZotope RX2 is 64-bit and works fine.
    ~jr
